In Reply to: No start 8N posted by Mike Maiman on November 29, 2022 at 15:07:27:
Folks a lot smarter than I, should be along shortly.
Harder and harder to start.
Gas in the bowl. That's nice. Pull the bottom plug out of the carb yet to check flow through the carby?
No? Pull the brass fitting at the carb and see if it's plugged.
Points closed up on you? Gap is what? Point gap effects timing.
Pull the #1 plug.
Crank the engine around until you start to get comp on the cylinder.
Now turn the engine by hand and line up your timing marks.
Pop the dist cap. Is the rotor aimed at #1 inside the cap?
Peace be with you.
