In Reply to: Re: No start 8N posted by Mike Maiman on December 01, 2022 at 16:22:20:
Well, then I would follow Bruce Haynes' (VA) advice about setting your ignition timing from scratch.
To recap: You have fuel that flows through the bowl via the drain plug, you get a 1/4" inch blue spark on all 4 cylinders, and you have bragging rights compression. Those are the three components you need for your engine to run. What's mystifying about this is that you say it did start initially but got harder and harder to start until it wouldn't. Makes me somewhat suspicious that your issue may be in your distributor. Do you have access to another, known good one to swap in?
