In Reply to: Re: No start 8N posted by Mike Maiman on December 02, 2022 at 18:00:38:
I've been following this all along and had no concrete suggestions. I wondered if the camshaft gear might have been slipping (thinking a pressed on gear like my early 9N has) but the later tractors all have bolt on cam gears so made no sense. Would like to see if changing only the rotor does the trick-that would make sense that it might be cheap plastic junk and wore immediately after installed.
I can only imagine from my periodic frustrations with my 48 occasionally not wanting to start when it normally catches on the first crank and finding no good reason for it, what you must have been going through. Glad you found it.
