Re: 48 8N. How much oil pressure is enough?
Posted by Tool Pro on February 01, 2023 at 16:47:03 [URL] [DELETE] :
In Reply to: Re: 48 8N. How much oil pressure is enough? posted by Jack Duncan on February 01, 2023 at 14:44:15:
No, air lien not causing the higher rate. The N's used a 0-50 PSI Oil Pressure Gauge. The 0-80 gauge came out with the larger NAA/Jubilee 134 engine. How old is the engine? when was the last time it was overhauled? That is probably your root cause problem. With engine cold, check the oil level with the dipstick. Start engine and let warm up at idle, do not rev up, for at least 15 minutes, good and hot for 30 minutes is better. Watch Gauge at idle start up, do not rev engine, and note. As engine gets hot it should start dropping a bit. If it gets to 10 PSI in a short time, engine needs a rebuild. System is worn out.
