Re: 1941 Ford Model 9N - Studs at the End of the Axle Housing
Posted by Bill Langenfeld on February 05, 2023 at 12:58:06 [URL] [DELETE] :
In Reply to: Re: 1941 Ford Model 9N - Studs at the End of the Axle Housing posted by Tool Pro on February 05, 2023 at 02:40:22:
Hello Tool Pro,
Thank you for your response! I checked out the Summit Racing link and this is exactly what I need (including the Grade 8 steel). What happened was when I was taking the axel apart on one side two of the studs came out with the nut as opposed to the nuts coming off of the studs. Then in the shop I removed the fine thread nut from the stud and discovered the threads were badly worn. The coarse threads that go into the rear axle housing looked OK on the 2 studs that came out. I'll see if I can run a 7/16-14 Tap into the hub to be sure the threads are OK for the 2 studs I removed. This ends several hours of internet searching. I'll be keeping the Summit Racing link as well as Dorman (the manufacturer of the studs).
Thanks Again, Bill.
