Re: 1941 Ford Model 9N - Studs at the End of the Axle Housing
Posted by Tool Pro on February 05, 2023 at 14:19:32 [URL] [DELETE] :
In Reply to: Re: 1941 Ford Model 9N - Studs at the End of the Axle Housing posted by Bill Langenfeld on February 05, 2023 at 12:58:06:
If you run a tap into axle housing might want to check if they are blind holes, I can't remember, but studs are often used in blind holes so get a mini-mag and pencil and look first. Best to use a bottoming tap if so -don't want to snap off the tap, have had customers do that B4 too. If you need a tap I can send you one - I have plenty. Sounds like you are on top of the game so good luck.
