Re: 1952 8n electrical problem
Posted by John Bear on April 08, 2023 at 13:52:20 [URL] [DELETE] :
In Reply to: Re: 1952 8n electrical problem posted by Bruce(VA) on April 08, 2023 at 11:16:21:
Hi Bruce, thanks for responding. Yes, I have 6.4 V at the distributor terminal and points open. From another posted comment, I also moved the battery (+) ground to the the oil filter bolt in the head to make sure there is good ground. Still no spark when pressing the interlock switch. Sparks only after I release switch while engine turns a couple more times. I am still suspecting the interlock switch or possibly the voltage regualtor which tat switch connects to? Thank you.
