Re: 1950 late model ford 8n tractor
Posted by Tool Pro on April 11, 2023 at 10:08:20 [URL] [DELETE] :
In Reply to: 1950 late model ford 8n tractor posted by steve burkett on April 10, 2023 at 07:17:39:
Steve, there is a lot of good information in the How-To's Forum here - SEE link below for bushing removal. The original Operator's Manual and the I&T FO-4 Service Manual have chapters on performing a tune-up and setting the timing correctly. New partS are available from JUST8N's and DENNIS CARPENTER. The new bushing, p/n 8N-12120, $5, may need to be reamed after it is pressed in. A press fit is .0005" so have you 0-1" micrometer out. Reamer may need to be found at a machine shop. The 8N side distributor is different than the one used after 1953 so be sure to get the correct parts.
