In Reply to: Help from croatia posted by Sokhar on April 15, 2023 at 00:51:26:
Hello Sokhar! Welcome to the NTC! It sounds like you are having problems with your ignition and charging circuits. Assuming that your electrical system is still 6-volt, positive ground, we can start with a wiring diagram that you can compare to your 2N tractor and go from there:
Hope this helps.........Ed
