Re: Headlight Switch
Posted by Ed Gooding (VA) on May 13, 2023 at 04:55:43 [URL] [DELETE] :
In Reply to: Headlight Switch posted by J52J on May 12, 2023 at 20:35:21:
Depending on your model and year, you connect the hot wire from your headlight switch to the center connector on the ballast resistor or the switched side of the terminal block.
I would ground my headlights to a bare metal area of the hood instead of the headlight shell.
