Re: Alexander
Posted by Ed Gooding (VA) on May 23, 2023 at 19:41:54 [URL] [DELETE] :
In Reply to: Alexander posted by Bobby on May 23, 2023 at 11:32:17:
You may need to prime your oil system. Remove the 15/16 hex nut to the right of the water pump ("D" in photo below). This is where your oil gallery is for the engine's valves/lifters. Be careful to not lose the little spring under the nut. Use an oil squirt can to put about a cup of oil in here. Replace the spring & nut.
