Re: FEL Pump
Posted by TheOldHokie on June 26, 2023 at 12:17:54 [URL] [DELETE] :
In Reply to: Re: FEL Pump posted by Charles Hudson on June 26, 2023 at 08:44:51:
Paper filters on the suction side are generally discouraged. Preferred practice is to have a 100 mesh wire strainer on the suction side and a 10-20u paper filter on the tank return. If that is a flooded inlet pump you will get most of the reservoir capacity out when you remove the filter....
TOH
