Re: 1950 8N carburetor and timing issues
Posted by Paul IN on July 13, 2023 at 10:59:12 [URL] [DELETE] :
In Reply to: 1950 8N carburetor and timing issues posted by Andrew on July 04, 2023 at 23:36:38:
Not familiar with the mag so can't help there.
Sounds like you could be having float issues with the carbs. Hold the float close to your ear and shake it and if you hear any liquid sloshing around inside, get a new one.
You can also try lowering the float a 32nd at a time to see if that helps.
Instead of using 1/4 inch bit, try a 9/32.
