Re: Caragata
Posted by Ed Gooding (VA) on October 18, 2023 at 05:32:33 [URL] [DELETE] :
In Reply to: Re: Caragata posted by john caragata on October 17, 2023 at 14:27:53:
When you swapped carbs did you check the filter screen at the fuel inlet to ensure it was not partially blocked? How about the filter screen in the sediment bowl?
When you open the fuel valve on the sediment bowl, are you opening it 2 turns or fully opening it?
