Re: Generator/Battery
Posted by Ed Gooding (VA) on November 09, 2023 at 05:47:33 [URL] [DELETE] :
In Reply to: Re: Generator/Battery posted by Travis Webb on November 08, 2023 at 20:38:03:
I've posted the link below to the procedure for testing/replacing your voltage regulator. If it tests ok, then you can move to your generator. You may just need new brushes in your generator. Ford engineered parts like generators, starters and carbs to be rebuilt many times so you can definitely overhaul it or have it overhauled if needed. Post back if you need further help.
