Stuck clutch
Posted by Island Mike on November 24, 2023 at 12:45:03 [URL] [DELETE] :
Have not used Herb 9N for a while. Have some ditch work to do. Engine fired, will not go in gear. Jacked up one rear wheel, blocked clutch pedal down, rocked wheel and the engine turned. HELP. Found it here. Looked up stuck clutch in the how to section.
Remove starter and pry the flywheel. Drill a hole and squirt carb cleaner. I went with the hole and spray plan. No go. Went to the big city for 2 days. Back. The wheel turned freely while in gear. Zoom Zoom and of to work we go. Wonderful resource here.
