Re: positive ground or negative ground
Posted by Bruce(OR) on December 28, 2023 at 02:09:18 [URL] [DELETE] :
In Reply to: Re: positive ground or negative ground posted by Bruce(VA) on December 27, 2023 at 21:30:39:
Unless you desire to test the depths of you pockets with a side dish of frustration.
Typically the 12V conversion becomes a slight possibility when a large ticket item or two, fails. Prior to that is a waste of finances when not needed.
