Re: Davis Loader mount?? model 101 or 801??? to fit my 801 ford
Posted by Jack - Iowa on January 14, 2013 at 22:01:23 [URL] [DELETE] :
In Reply to: Davis Loader mount?? model 101 or 801??? to fit my 801 ford posted by Adam on January 14, 2013 at 11:38:54:
Adam,
I also bought a Davis Loader last fall without the mounting brackets. I believe it is a 102. The difference between the 101 and 102 is the number of cylinders used to tilt the bucket.
I was able to track down the tractor from which it was removed and get pictures of the front mount. I've visited that tractor twice taking measurements also.
Unfortunately, the pictures are on my farm computer which currently is down with a bad power supply. I do have a drawing which I have made of the mountings. I HAVE NOT built it yet to prove my drawings!
I can print this drawing off in sections in pdf format and email it directly to you. Once one of us has proved the dimensions, I will work on getting it posted here on the board.
Try to get it done tomorrow. Will also try to retrieve the pictures from the other computer.
Mine will be mounting on a 860 tractor.
Jack
Posting not permitted in the forum archives.<1358218883">
