In Reply to: 1948 Ford 8N fender mounting brackets posted by Jim Knecht on May 03, 2024 at 09:25:20:
I'm confused by your request. If you took these fenders off to install the loader, they should easily fit back on. I have had many Ford Ns. 2 8Ns with loaders, a 9N with a loader and an NAA Jubilee with a loader. Fenders with script Ford on them and fenders without, will all fit any of these tractors, oriented correctly and mounted to the axle housings with plenty of clearance to the tires. I've had tires sizes from old 10x28s to 13.6x28s. No problem.
If you have purchased fenders that are not correct for an 8N, I can see that might be the problem. hth
