Posted by Randy(PA) on October 06, 2007 at 23:49:08 [URL] [DELETE] :
In Reply to: DEARBORN & FORD GREASE GUNS posted by Tim Daley(MI) on October 06, 2007 at 22:07:00:
Bracket 250032 (recently seen on eBay) was drawn in March 1948 by the supplier American Forging & Socket Co. of Pontiac, MI. and it has an offset tab (with two holes) spot-welded only on the left end, instead of one hole in each end, as this catalog shows. I would assume this 1950 version is an improvement from the fatigue perspective (probably cost less to produce as well). I wonder if the part number changed for this improved part.
If you press "Preview Message," you are taken to a preview screen where your
message is shown to you before allowing you to post it.
Your message is not finalized until you click "Post Message".
HWForums.com Message Forums
Copyright © 2001 HighWired Internet Innovations Inc. All rights reserved.
