Differential check
Posted by Larry on October 16, 2024 at 23:57:01 [URL] [DELETE] :
Re: my last post about UTF, I read that the oil in the differential should be high enough to touch it with a finger inserted in the differential case after removing the cover. My NAA diff was pretty dry and I could not see any oil in it at all. When I add fluid, is it true that I should fill it up until I can touch the oil with my finger? As always, Thanks
