Re: 1949 8N No Start
Posted by Hank Etue on February 16, 2025 at 17:32:00 [URL] [DELETE] :
In Reply to: Re: 1949 8N No Start posted by Bruce Dorsi on February 10, 2025 at 00:13:43:
Hi Bruce
Was finally able to get out to the tractor today temp up to freezing now.
So after cranking and checking plugs they are dry. so pulled breather pipe off carb and hand over inlet of carb have some suction there but hand is dry even after chocking it. So this leads me to believe like you have said a vacuum leak. My jets
are Main is at 2 turns out and the idle mixture is 1.5 out. so thought let you know where i am with it? So you think it may be in the exhaust area where i need maybe new
gaskets i the intake side maybe not sure.
