Re: Early 8N Resistor
Posted by HCooke on May 06, 2025 at 10:40:28 [URL] [DELETE] :
In Reply to: Early 8N Resistor posted by Bob WA on May 05, 2025 at 16:16:53:
Jump around the resistor. Will the tractor start? If so the problem is the resistor. If not, the problem is in the ditributor (points). If it starts and runs and you have a 12 volt coil it should be OK.
