Re: 8n tractor hard to start
Posted by Farmer Brown on May 18, 2025 at 05:45:29 [URL] [DELETE] :
In Reply to: 8n tractor hard to start posted by Rocky Logan on May 17, 2025 at 19:21:31:
I would start with a tune up of the ignition system. That includes plugs, cap, rotor, points and condenser. Make sure the air filtering system is clear. The fuel system should be gone over which includes the sediment bowl and there is a filter coming out of the bowl, I believe. The tractor also needs to have a battery being in good shape to operate.
Addressing these normal maintenance items may solve your issue. If you continue to have problems, you can repost but you need a good baseline having a sound ignition and fuel systems.
