Re: Two questions…1952 8N
Posted by farmer Brown on July 27, 2025 at 13:08:06 [URL] [DELETE] :
In Reply to: Two questions…1952 8N posted by Dead Eye Dave on July 27, 2025 at 10:57:05:
The two may be related. It points to the carb. Possible float issue and may be sticking. Sounds like the engine is lean. By applying choke, you are basically richening the air/fuel mix by cutting back the air flow.It may be time for a carb rebuild.
