Re: 8N Live Hydraulics
Posted by Ed Gooding (VA) on January 19, 2026 at 06:58:49 [URL] [DELETE] :
In Reply to: 8N Live Hydraulics posted by Brian Gruszynski on January 17, 2026 at 09:19:20:
Brian, are you referring to Kevin LaRue's tutorial? If so, I believe that his solution replaces the internal hydraulic pump rather than supplementing it for other operations. If I am right, then yes, you would need to chain your rear lift down to operate a front-end loader.
If you want to install a loader, an alternative that most folks use is to install a pump to the front pulley and run it from the crankshaft. You will need a separate valve to control loader operation and a dedicated supply for hydraulic fluid, which is usually stored in the frame of the loader.
If you are using Kevin's tutorial, you can email him directly to confirm at kl@myfordtractors.com.
