1949 8n axle shim placement
Posted by Cliff hodson on February 06, 2026 at 15:47:43 [URL] [DELETE] :
I’m replacing rear axle seal as it was leaking. It has metal shims of different thicknesses. When i took apart all 4 shims were behind the dust plate. The book shows different locations when putting back together. Anybody know the determinig process as to where these go. I ordered new ones and they are all the same thickness. They also take both tires off and turn axles should rotate different directions and that if not spaced properly axles will weld themselves together inside. Any help is appreciated
