Re: 8N parasitic draw 6V
Posted by Dean on March 08, 2026 at 19:49:15 [URL] [DELETE] :
In Reply to: 8N parasitic draw 6V posted by TravisUT on March 08, 2026 at 15:36:44:
Absent a short to ground somewhere or, perhaps a welded (stuck) VR contact, there should be no "parasitic draw" in your OEM 6V 8N electrical system.
That said, your generator should generate 8+ volts while charging a discharged 6V battery.
Your voltage readings to 2 decimal places tell me that you are using a digital multimeter to measure voltages. Absent a good DMM that will accurately measure RMS voltage, you cannot successfully use an inexpensive DMM to measure voltages in a charging system using a vibrating contact voltage regulator.
Sounds to me that your charging system is operating as it should.
