Re: Timing..No Spark
Posted by Ed Gooding (VA) on August 31, 2026 at 08:44:38 [URL] [DELETE] :
In Reply to: Re: Timing..No Spark posted by joe in wilkinson on August 31, 2026 at 07:26:28:
If you timed it on your bench per the instructions, then it should be timed close enough to start.
Have you tried running a wire directly from your battery to the coil to see if your issue is the ballast resistor or wiring from it to the coil?
