Re: Removing crankshaft pulley - 1952 8N
Posted by K.LaRue-VA on April 20, 2013 at 23:02:39 [URL] [DELETE] :
In Reply to: Re: Removing crankshaft pulley - 1952 8N posted by K.LaRue-VA on April 20, 2013 at 22:57:51:
Why not just reach in there with a pry bar and straighten the pulley on the engine? If it's bent the way I think it is, Bump the engine around until you see where you need to pry. Don't over-do it and you should be able to make the pulley run true.
Posting not permitted in the forum archives.<1366513358">
