Re: 9N runs bad
Posted by Bruce (VA) on April 28, 2013 at 16:52:02 [URL] [DELETE] :
In Reply to: 9N runs bad posted by Mark on April 28, 2013 at 12:17:30:
There are two schools of thought when it comes to getting a non-running tractor to start. One way is to just start replacing every part you can get to until it starts or you run out of money. The other way is to take a step-by-step approach to solving the problem, working from most likely to least likely. The trick to fixing these tractors (or trouble shooting any piece of equipment) is to be systematic about it. You need to isolate the problem step by step and work from most likely to least likely.
Use the "gut feeling" approach to test your wife's new chili recipe. As Kevin said, leave the carb alone until you eliminate other more likely causes of your problem.
Pulling out the choke gives you a richer mixture. So, you could have either a fuel or spark problem.
A carb out of adjustment will also cause this problem; set the main jet at 1-1/2 turns out & leave it alone.
A dirty carb can cause the problem as well; start by cleaning the fuel screens.
Dirty/old gas, or water in the gas can cause this problem.
Restricted fuel flow can cause this problem; remove the bolt at the bottom of the carb & check for flow.
On my 1950 frontmount, needing choke to run is the first sign that the points need adjusting/replacing.
A vacuum leak can do the same thing. Get a hand propane torch and carefully spray it (unlit of course) around the intake manifold at the carb to manifold interface & the manifold to block gasket of the tractor while it is running. Or, you can use carb cleaner or WD40. If it speeds up, you found the leak. Sometimes (rarely) manifolds crack or get rust holes.
Lastly, when all else fails, you could have an air leak around the carb metering section. The likely suspects are leaky throttle shaft seals and/or a worn throttle shaft. Or, just a real dirty carb w/ clogged passages.
Bottom line: Probably 90% of "needs choke to run" problems are fuel related, but do not rule out ignition problems, contrary to what others may tell you. I’ve had that very same problem before w/ a rebuilt carb, fresh fuel & good flow & a tight manifold.......and it was a spark problem. But, that was unusual. Just check the likely fuel problems first.
Please be sure to post back & let us know what the fix was. We all learn something if you tell us what worked!
Posting not permitted in the forum archives.<1367182322">
