Re: Generator not charging on 6 V 49 8N
Posted by raven on June 07, 2013 at 11:23:51 [URL] [DELETE] :
In Reply to: Re: Generator not charging on 6 V 49 8N posted by JMOR on June 06, 2013 at 11:15:54:
So, if generator motoring is not a conclusive procedure to test, if only, the generator is working properly ,then the original question is what is the best procedure.
The generators needs to be tested as a single unit.
The first step is to polarize the generator and verify it is polarized correclty using the needle type VOM
The VR needs to be tested as a single unit
and
the generator/VR/battery system need to be tested all together,
Posting not permitted in the forum archives.<1370618631">
