Re: 53 ford naa hydraulic loosing prime and pulsing full lift
Posted by peter on July 02, 2013 at 10:21:19 [URL] [DELETE] :
In Reply to: Re: 53 ford naa hydraulic loosing prime and pulsing full lift posted by Kurt-NEPA on July 02, 2013 at 06:17:56:
kurt, the tractor was running and when i lift the back blade and shut off the tractor it does slowly fall to the ground.(takes 1-2 hours at the most to fall completely). it is very hard to see inside through the inspection cover but i couldn't see anything else that had a leak of any amount, but small ones could have been missed. thanks for the help. looks like time to start getting parts and i will go through zane's post again and make sure there isn't anything else i should check before tearing into it.
Posting not permitted in the forum archives.<1372774879">
