In Reply to: Re: 9N 1000C Generator posted by Corey on July 19, 2013 at 17:09:56:
Corey-
Here are some photos of the correct 2N-10000 generator with the factory installed tensioning bracket. One piece bolted to the barrel with two 1/4-28 x 5/8 hex head bolts and another piece bolted to the head with the two nearest studs and nuts in front. The spring and bolt then assembled between them. To mount one, be sure to bolt the head piece first. You may have to drain some coolant from radiator before you start. Shown here are a 2N10000 generator and bracket I recently restored and painted 9N Gray. The last photo shows a correctly mounted 2N10000 generator.
Posting not permitted in the forum archives.<1374323315">
