Re: Throttle Control Rod Removal
Posted by mhb@ufe on October 26, 2013 at 07:29:24 [URL] [DELETE] :
In Reply to: Throttle Control Rod Removal posted by Acadianbob on October 25, 2013 at 21:56:31:
Unless someone has made up something else it is spring loaded like all the other throttle rods. While you have it off you should also replace the seal for the governor shaft as that usually leaks more than the mounting gasket.
Mark
Posting not permitted in the forum archives.<1382786964">
