In Reply to: Re: Touch Control posted by ZANE on November 21, 2013 at 20:04:56:
Zane,
I'm not ready to do this project yet, but I will be in the next couple months. Can I get your contact info so I can order the jig kit?
While i'm thinking about it. Should I do anything else while I have the pump dropped and lift cover off? Should I take the transmission cover off and clean that area as well?
This is a different problem I'm having. After the tractor sits a day or so and I let the clutch out, with it in gear, I hear "POP" coming from the rear and sometimes "POP" "POP". After it does this it wont do it again until it sits. I'm thinking is break related, but I don't lock the brakes after I'm done. The PTO is disengaged, and it seems to come from the right more often. I can start a new topic if you think that's best.
Thank you,
Tim
Posting not permitted in the forum archives.<1385128797">
