Wont Start - part 2
Posted by TB in MN on January 29, 2014 at 19:04:40 [URL] [DELETE] :
Recap - Yesterday finally started my 12 v front mount 2n. Had magnetic heater on intake manifold and had just torched the spark plugs.
Today I tried again 25 degrees warmer (20 degrees F today) and no heater on the intake manifold. Refused to start. Each time I would choke only after no pop was received w/o choke. Occasionally it would pop once at a time at the end of a choke. Pulled plugs and torched after each try. Torched plugs would turn over a couple successive pops initially but not enough to run. Subsequent tries were back to the one at a time pop until I torched the plugs again. After I torched the plugs for the third time I didn't use any choke and them pulled the plugs to inspect. I found two of the plugs had been flooded without using the choke after only 2 starting tries. One of them a drop bridged the electrodes, the other had a drop forming on the electrode. Does this point to a fuel problem?
Thank you,
TB in MN
Posting not permitted in the forum archives.<1391040280">
