Re: CABLE OVER HYDRAULIC STEERING
Posted by TONY JACOBS on April 25, 2014 at 19:59:07 [URL] [DELETE] :
In Reply to: Re: CABLE OVER HYDRAULIC STEERING posted by KCM on April 21, 2014 at 16:50:26:
Hello KCM , To bleed air from the hydraulic system you have to disconnect the rod end of the cylinder from the axle to achieve full stoke in both directions otherwise you will never remove the air . When the oil stops foaming just bolt it back up and you will be all set . Thanks Tony
Posting not permitted in the forum archives.<1398473947">
