In Reply to: Re: CABLE OVER HYDRAULIC STEERING posted by TONY JACOBS on April 25, 2014 at 19:54:57:
The pitting was actually on the inside of the outer tube, where the valve housing o-ring seals against the outer tube. There was no boot, and I found dirt inside that I'm sure trapped moisture. Could have also gotten dirt in where the holes for the lines are as well. The tractor was sitting outside for a couple years, getting rain water in through the openings, which didn't help matters.
Posting not permitted in the forum archives.<1398746259">
