In Reply to: ford 9n posted by Geoff Muller on July 09, 2014 at 00:33:40:
COLORS OF PARTS
The color information has been provided by others. The following table has all the information I could find regarding different colors for various parts. I apologize in advance for errors that may apply to a particular model. For instance some early 9N tractors did have a few extra chrome pieces.
| PART NAME | 8N | 9N/2N |
| Air Cleaner | Red | Dark Gray |
| Axle Housings | Red | Dark Gray |
| Axle Hubs | Red | Dark Gray |
| Battery Cable | Black Insulation | Black Insulation |
| Battery Cover | Red with Decal | NA |
| Battery Tray | Red | Dark Gray |
| Battery/Fuel Door Knob | Black | Chrome |
| Battery/Fuel Door | Lt Gray | Dark Gray |
| Brake Drums | Red | Dark Gray |
| Brake Pedals | Red | Dark Gray |
| Breather Cap | Red | Dark Gray |
| Cable Ends and Hardware | Unpainted | Unpainted |
| Carburetor | Red or Unfinished | Unfinished |
| Choke Knob | Unpainted Metal or Black | Unpainted Metal or Black |
| Clutch Pedal | Red | Dark Gray |
| Cylinder Head | Red | Dark Gray |
| Dash Panel | Red | Dark Gray |
| Distributor Cap | Unfinished | Unfinished |
| Drag Link | Red | Dark Gray |
| Drawbar | Red | Dark Gray |
| Engine Block | Red | Dark Gray |
| Fan Belt | Black Rubber | Black Rubber |
| Fan Shroud | Red | Dark Gray |
| Fan | Red | Dark Gray |
| Fender Brackets | Lt Gray | Dark Gray |
| Fender Mounting Bolts | Cad Plated | Cad Plated |
| Fenders | Lt Gray | Dark Gray |
| Ford Emblem | Red with Chrome Script and Border | Blue with Chrome Script and Border |
| Front Axle Extension | Red | Dark Gray |
| Front Hubs | Red | Dark Gray |
| Front Rims | Lt Gray | Dark Gray |
| Front Timing Cover | Red | Dark Gray |
| Fuel Line | Unpainted-Steel | Unpainted-Steel |
| Fuel Tank | Cadmium-Plated | Cadmium-Plated |
| Gearshift Boot | Black Rubber | Black Rubber |
| Gearshift Knob | Red 1-Piece (early) Black Plastic (later) | Dark Gray |
| Gearshift | Red | Dark Gray |
| Generator | Red | Dark Gray |
| Grill | Lt Gray | Dark Gray |
| Ground Strap | Unpainted | Unpainted |
| Guage Faces | Black-White Letters | Black-White Letters |
| Guage Trim | Black | Black |
| Headlight Housings | Lt Gray - Plated Screws | Dark Gray - Plated Screws |
| Hood Side Skirts | Lt Gray | Dark Gray |
| Hood | Lt Gray | Dark Gray |
| Ignition Switch | Unpainted | Unpainted |
| Light Switch | Unpainted | Unpainted |
| Lug Nuts | Zinc Plated | Zinc Plated |
| Manifold | Unknown | Unknown |
| Muffler and Pipe | Zinc Plated | Zinc Plated |
| Oil Filter Bolt | Zinc Plated | Zinc Plated |
| Oil Filter Housing | Red | Dark Gray |
| Oil Pan | Red | Dark Gray |
| Position Control Lever | Red | NA |
| Proofmeter Face | Black-White Letters | NA |
| Proofmeter Trim | Black | NA |
| PTO Knob | Red or Plain | Dark Gray |
| PTO Lever | Red | Dark Gray |
| PTO Shaft Cover | Red | Dark Gray |
| Radiator Cap | Black | Chrome? |
| Radiator Hose | Black Rubber | Black Rubber |
| Radiator | Black | Black |
| Radius Rods | Red | Dark Gray |
| Rear End Housing | Red | Dark Gray |
| Rear Rims | Zinc Plated | Zinc Plated |
| Rear Wheel Centers | Lt Gray | Dark Gray |
| Running Boards | Red | Dark Gray or None |
| Seat & Spring | Black | Dark Gray |
| Spark Plug Wire Tube | Cadmium-Plated | Cadmium-Plated |
| Spark Plug Wires | Unpainted-Black | Unpainted-Black |
| Spark Plugs | Unpainted | Unpainted |
| Starter Button | Unpainted-Steel | Unpainted-Steel |
| Starter | Red | Dark Gray |
| Steering Wheel Nut | Plated Acorn Nut | Plated Acorn Nut |
| Three-Point Hitch Arms | Red | Dark Gray |
| Throttle Lever Base | Cadmium-Plated | Cadmium-Plated |
| Throttle Lever | Cadmium-Plated | Cadmium-Plated |
| Tie Rods | Red | Dark Gray |
| Timing Cover Bolts | Zinc Plated | Dark Gray |
| Toolbox | Red | Dark Gray |
| Touch Control Lever | Red | Dark Gray |
| Transmission Housing | Red | Dark Gray |
| Valve Covers | Red | Dark Gray |
| Wire Harness | Unpainted | Unpainted |
Posting not permitted in the forum archives.<1405117750">
