In Reply to: Re: 8N Oil Pressure posted by Farmer Brown on May 28, 2024 at 23:28:11:
Thanks Farmer Brown; I did forget to purge the air out. I disconnected the line and did that, and then re-connected. The needle still bounces, but not as bad; I can live with it for now.
I'm still getting around 20 PSI on startup, and warm, and when full throttle about 25 PSI. Next time I change the oil, maybe I'll give it some heavier weight oil. Is 20 ok to run it for now? How low is too low?
Posting not permitted in the forum archives.<1717029006">
