In Reply to: Re: 6 volt generator posted by Steve Dabrowski on November 11, 2012 at 15:06:36:
Come on fellows......" Therefore polorization is normally accomplished by hooking up the battery properly as the positive ground immediately supplies voltage to the grounded field ckt.".......this is NOT the case!! BECAUSE, the cut out will be open, therefore no current will flow! So no polarization will not occur until you short across the cut out, thereby connecting the Neg batt to the Armature, where the field is then supplied by way of the non-grounded brush.
Posting not permitted in the forum archives.<1352667048">
