Re: Jubilee Oil pressure
Posted by charles in louisiana on December 30, 2012 at 17:26:10 [URL] [DELETE] :
In Reply to: Re: Jubilee Oil pressure posted by Alan Currie on December 28, 2012 at 22:58:37:
pop rod bearing out. and one main. the back will be marked..as std.. or if overside in thousandths. as .010 or .012, etc. i have seen different turnings on same crank. as rods may be only .010 over and crank as .020 over. plasti-gauge everything. regardless who did the work. and check every rod, and main . mistakes happen. better to know ahead of time. it only takes hour or so. even if i am overhauling and going with same size bearings. i check. i got wrong rod bearings onec long ago in a 61 buick 364 cu.inch. luck charles
Posting not permitted in the forum archives.<1356906370">
