Re: side mount sickle mower for a Jubilee?
Posted by Ed Gooding (VA) on August 02, 2007 at 16:59:20 [URL] [DELETE] :
In Reply to: side mount sickle mower for a Jubilee? posted by Geoffrey Cunningham on August 02, 2007 at 16:20:24:
Hi Geoffrey. You can definitely get a belly-mount mower, but it will essentially turn your NAA into a mower only. If you have another tractor(s), that may not be an issue for you. The belly-mounts, even those made by Ford for Ford tractors, are a pain to attach/detach, so most folks leave them on.
The 502 series is the belly-mount equivalent of the 501 rear-mounted mower:
fwiw..........Ed
