Curious about the best order to paint my 8n.
I could paint everything individualy and then assemble as this would allow me to prime and top coat staying in the recoat window (epoxy the single stage). Would likely have lots of touch ups from assembling everything tho. Alternatively I could prime everything and topcoat the hidden or difficult to get at spots, then assemble. This would put me out of the recoat window tho and I would need to sand the primer areas and scuff the exposed top coat before topcoating the entire thing again. I would suspect there is better adhesion if the topcoat goes on within the recoat window tho?
What is everyones preferred sequence?
Thanks
