Re: 2n 12 Volt question
Posted by Ed Gooding (VA) on July 26, 2025 at 18:38:07 [URL] [DELETE] :
In Reply to: 2n 12 Volt question posted by Steve_Pfost on July 26, 2025 at 17:24:51:
Whether you need the rectangular resistor depends on the coil that was installed. IF you installed a 12v coil, you do not need the extra, rectangular resistor. If you kept a 6v coil, then you do need it. Which coil was used?
