In Reply to: Golden Jubilee shifting problems posted by Hank Hoffman on August 31, 2025 at 08:10:47:
I had similar experience about 50 years ago on the '51 8N that I had been driving since 1953 (still have it). I bought all new clutch parts, broke the tractor in half and installed. Bolted up and adjusted the clutch. Problem still existed. Broke tractor apart again, checked everything, reassembled...problem still there. Adjusted and adjusted clutch linkage, no help.
I finally talked with a mechanic at my local Ford Tractor Dealership. WA LA! He had the answer! It was NOT an internal problem! It was the external linkage, 8N7511B Years:1948-58 Arm (Clutch Release Shaft) (Available at Just 8Ns)
I call it a "dog bone" link. One end attaches to the adjustable clutch link. The other end connects to the clutch shaft with a cold roll pin. That was the location of the problem.
Try this: ENGINE OFF!: block the tractor wheels; either clamp down the clutch pedal or have someone depress it and hold it down. LOOK at the bottom side of the "dog bone" and clutch shaft. Look for an open crack in the dog bone between the cold roll pin and the transmission case. Release the clutch and watch the crack close.
Good luck. Let us know what you find.
PS The exact same part is used 1948 to 1958.
