Re: Seeking help to rebuild 9N distributor
Posted by Ed Gooding (VA) on October 28, 2025 at 08:59:10 [URL] [DELETE] :
In Reply to: Re: Seeking help to rebuild 9N distributor posted by HM Skeezix on October 28, 2025 at 08:49:31:
A couple more ?s:
#1 and #3 meet the minimum, and #4 is close enough. Did you run both a dry and then a wet compression test to help indicate rings vs. valves on #2?
Are you still 6v, or have you converted to 12v?
Is the starter cranking, but the engine won't start, or not even cranking?
