In Reply to: Sometimes Its The Simplest Thing!! posted by Del Huebner on March 18, 2013 at 18:46:18:
Remember the case of the erratic idle issue. The solution was one of the throttle link ends was worn out and causing excessive play in the link.
Looked at the link connected the governor that is currently removed from my own 49.
Yes, the link has a bend in it. Now understand why the link is bent.
The bent link measures 7.00" straight lenth end to end, not pivot to pivot.
The part no 9N9818A indicates the link equals 7 inches long from the YTC online catalog description.
The throttle link ends can be adjusted to vary the pivot to pivot length.
There is another part listed in the 39-49 parts manual with part no. 9NAN 9818 for 39-49. Part No. 9N9818-A , also shows up in the 49 parts manual.
"Just 8N parts catalog" has a part no 9N 9815-B described as 10-3/8" length for years 39-47.
and part no EAF 9818-C for 53 to 64
However, does not list 9N 9818-A ....probably out of stock
Find the whole thing rather confusing.
Posting not permitted in the forum archives.<1363672366">
