In Reply to: Re: New 9N Steering Sectors posted by Jim.UT on March 30, 2013 at 04:42:07:
Jim,
If you look at the last photo you can see the clutch actuator I got from you installed. I retained the shaft and welded up the bearing surfaces then turned them down to the correct diameter, then after installing new bushings, installed the shaft and actuator. I also filled the clevis pin hole and re-drilled it for centering and size. Worked out really well.
Posting not permitted in the forum archives.<1364917242">
